View Poll Results: A poll
Diesel
84.62%
Gas
15.38%
Voters: 26. You may not vote on this poll
Which kind of truck is better?
Old 01-02-2005, 05:49 PM
FordFreak's Avatar
Default Which kind of truck is better?
Old 01-13-2005, 06:15 PM
Default RE: Which kind of truck is better?
What are you going to be doing with IT????????????
Old 01-16-2005, 12:29 PM
If you haul heavy loads a diesel is better. If you use it as a daily driver I would go with gas.
Old 01-18-2005, 04:37 PM
I am allergic to diesel fumes so I have to buy gas! Anyone else in my same boat.
Yes, and I get sea sick easily ((( Sux big time!
Old 01-23-2005, 01:20 AM
josser's Avatar
I say diesel engine because whether the truck is fully loaded or not loaded at all you get the same milage. Gas engines uses more fuel when fully loaded and less when not loaded at all. And Diesel consumption is not affected by the environment or how many gadgets your truck has. Also Diesel gives you more power 6.0 turbo diesel with 600hp and 500 foot torque pounds or the gas engines 5.4L 302hp 345 f-t-p V-8 or 6.?L 355hp 425 ft-t-p V-10. The diesel engine will set you back between $6-8,000 depending were you live. Diesel also cost about the same as the mid grade gas. Consider the f-150 or even the f-250 light duty, they look like the f-150's but can hawl and tow more and are not quite as much as an f-250 super duty.
Old 01-23-2005, 02:28 AM
And the new 6.0 Diesels have more hp and torque compared to the 7.3 Lthey replaced...amazing!!
Old 01-24-2005, 08:05 PM
trader, your jokeing about the diesel and the seasick thing right?
Old 01-25-2005, 02:34 AM
Shoot, I wish I was. It sucks when I cant even sit n the back seat of a car. No matter what car I am in, I drive. And that really sucks on long trips. I have tried Dammamine (sp) and it just knocks me out!
Old 01-25-2005, 01:15 PM
You know, when I'm on the road and I'm not driving, I can't for the life of me take a nap, I just can't. Might as will just drive
Old 01-25-2005, 01:20 PM
I can sleep on a plane...unless there is a lot of turbulence. I think my sickness is based on turns and swerves. Sometimes when I use to ride my quad at the dunes I would get a bit nautious and would have to stop for a cold one.... maybe I just wanted a cold one...hmmmm!!!
Quick Reply: Which kind of truck is better?
