Losing power on incline
Old 02-22-2012 | 12:27 PM
resinman's Avatar
Unhappy Losing power on incline
I have an F1 50, 1994, 5.0, I'm driving on steep inclines I start to lose power I don't know if it's fuel pump on the throttle body assembly or something has anybody experienced this problem and know how to fix it thank you. Jeff
Old 02-22-2012 | 12:55 PM
Hi Jeff,
Could you furnish some addl info?
Mileage on vehicle
What if anything have you done or had done so far
Are these inclines on the roads where you normally drive
Old 02-23-2012 | 10:57 AM
resinman's Avatar
Default Losing power
Hi I have I have roughly 221,000 miles on it, that's on the truck put a new short block in at hundred thousand, I put new fuel filter on new plugs distributor cap and rotor, doesn't do it all the time only on inclines on flat surfaces it's fine around town it's fine the more I read about what this is I'm leaning more towards the fuel pump I do believe it's original pump on the truck so maybe that's it but that's why throughout you guys for some help, thanks Jeff
Old 02-23-2012 | 01:14 PM
Gary2Wheels's Avatar
have you ever changed the catalytic converter?.. do you smell dirty exhaust gasses?..
Old 02-23-2012 | 07:41 PM
Did this problem just start recently or have you had it for quite a while? I am wondering if the initial timing is set correctly.
Old 02-24-2012 | 01:04 PM
resinman's Avatar
Gary, as far as I know that's the original catalytic converter, it does smell little funky, is there a way to test it to know if it's good or bad, thanks
Old 02-24-2012 | 01:06 PM
resinman's Avatar
Hanky, the problem comes and goes doesn't do it all the time I guess I'll have the initial timing check to see if that's set right, thanks Jeff
nuckleball5
10-16-2012 10:26 PM
OLDBLUE87
11-20-2011 07:26 PM
dmattin2
09-12-2007 11:14 AM
fordstang
03-11-2007 03:12 PM
jfrank3
10-18-2006 09:35 AM
