Low pressure warning light
Hi Guys and gals I’m new to the forum but not to Ford. That being said I recently bought a beautiful used 2020 F-250 Super Duty. I just love the truck stock but really wanted it lifted so I had a 4 inch lift installed with some sweet 37s. My problem is the tires I bought are D rated and not E, so max pressure is only 50 PSI which as you know is about 20 PSI short of stock pressure so the low pressure light is on on the dash. I can’t exchange the tires because they were already mounted on rims so “SimpleTire” the on line company I bought them from will not exchange them. So do any of you know a fix for getting the dash warning light out. Thanks in advance.
Thanks Scott I was afraid of that but I was hoping some Ford gear head found a way around it
