Lowering 2017 F350
Old 12-10-2017 | 05:56 PM
Ted Frost's Avatar
Default Lowering 2017 F350
I have 2017 F350 dully 4×4. have problem with the height of bed rails. They are higher then previous truck. Problem occur8 when trying to use 5th wheel hitch. Don have minimum 6 inch clearance. Can the truck be lowered to provide additional clearance
Old 12-11-2017 | 10:31 AM
Welcome to the site..
6” at the bed rail ends, meaning the truck sides and combined height are crowding clearances there, correct? What measured clearance is there now?
Old 12-11-2017 | 03:17 PM
Ted Frost's Avatar
As mentioned, don't have 6 inches minimum. Only have about 3. I can get an adjustment to the RV to raise it1 inch. Still need 2 more inches. Problem is with the higher bed rails height of new 2017 Ford.
Old 12-12-2017 | 10:10 AM
The 1” adjustment is at the pin box?
If the trailer axles can be flipped, that would gain some clearance. Replacement pin box. Lowering the truck would be difficult.
My 17 sits about 4” higher than my 05 did at the rails. Not sure why all the manufacturers feel the need to make bed access more difficult. Even using the gate step, a good hike up/down to the step plate.
brantm21
12-16-2006 03:06 PM
nmitc2003
11-06-2006 03:42 PM
darita
10-25-2006 11:46 PM
atwooddon
10-04-2005 10:17 PM
•FLaCO•
08-22-2005 03:36 PM
Quick Reply: Lowering 2017 F350
