misaligned pulleys
Old 08-28-2006 | 09:39 PM
93f250xlt4x4's Avatar
Default misaligned pulleys
i have a 93 f250 351 and how can you telll if the pulleys are misaligned and how can you fix it.
Old 08-28-2006 | 10:49 PM
94 4x4 ranger's Avatar
Default RE: misaligned pulleys
The pully's do not missalign them self . If they do the pully is loose or the bearing is shot and will sqeal. You will have to replace it.
Old 08-29-2006 | 04:02 PM
Usually the only belt alignment issues are from an incorrect P/S pulley install if the P/S pump has been replaced.. Sometimes the pulley is pressed on too far, or not far enough.. It also can be damaged/worn from 'multiple' prior installs/work and may possibly 'walk' on the shaft.. Had one on a 7.3 just weeks ago.. The correct placement for the P/S pulley is 'flush' on the pulley hub/face with the pump shaft.. On rare occasion, a reman. water pump may have the pulley/hub installed wrong, shallow or deep, but not very likely, and even less likely an issue for the 5.8, as the belt runs flat on its backside over the pump pulley and has 'some' range of service area.. It's not very common any more for misaligned fead belts as their drive components are pinned/bolted to their mounting casting.. Unlless mismatched idlers are installed, or part quality issue.. Not like 'days of old' when Ford used multiple spacers, pressed steel mounting brackets and different pulley combinations and such.. A misaligned belt in most cases will have a shorter life, or may shred.. If the belt were to loose surface area, become glazed, and/or have a tension problem it will squeal on accell. but not at idle.. With the wide surface area of the fead belt, just sighting across the belts length usually gives you an idea of a misaligned belt path..
Az68Tbird
02-11-2007 03:07 PM
gags61
04-09-2006 01:59 AM
gags61
04-04-2006 10:17 PM
Quick Reply: misaligned pulleys
