need help fast
Old 09-03-2006 | 05:23 PM
93f250xlt4x4's Avatar
Default need help fast
my 93 f250 351 wont start. at work today i started the truck and it ran for a good 5 seconds then stalled then i i turned the key again and it would just crank not start. i thought i had no gas so i went and put gas in and it started up for like 6 seconds then died again. so i left it alone for like 10 minutes and then i started it and it ran for about 2 minutes and shut off. i have no clue what to do. if i let it sit for a couple of minutes and try it it will start but only for a couple of seconds. please help me asap
Old 09-03-2006 | 06:55 PM
94 4x4 ranger's Avatar
Default RE: need help fast
Might be the fuel pump relay in the power distribution box under the hood.Swap it with the A/C relay or EEC relay and see if it starts.
Old 09-03-2006 | 09:53 PM
i got it too start i went back later on and i started it and gave it gas and it started . my friends thinks its because i have a msd ignition box and that got wet and it was also sitting on my plow solenoid can this be my problem
Old 09-03-2006 | 10:00 PM
A wet msd ignition box might do it. I would not go to far until you are shure thow.
Old 09-04-2006 | 04:07 PM
Mulletman's Avatar
If it runs with the gas slightly depressed, then the IAC valve may be gummed up.
leebolinsky
12-13-2010 10:41 PM
POPONG827
10-10-2007 10:44 PM
Sohka
03-21-2007 02:42 PM
Dis@ster07
10-27-2006 09:10 PM
benenrond
01-05-2006 12:57 AM
Quick Reply: need help fast
