Need help on steering problems.
Old 04-19-2007 | 01:05 AM
Billyb's Avatar
Default Need help on steering problems.
Hi,
OK, i own a 2003 F-250 4WD and i'm having steering problems. My truck came with 265-75-16 tires and i up graded to 285 and then from there i upgraded to 305-75-r16. When i had the 285 on the truck, right before i took them off the truck started to walk towards the left, it did not pull to where you could feel it but it kinda veered to the left to where you had to pull it back. I had it lined up the other day but it did'nt help a bit. Soomeone told me that i might have to go to a stablelizer bar to get rid of the steering problems. Or did someone line the front end up incorrectly? Any advice would be greatly appreaciated.
thanks,
Billy
Old 04-19-2007 | 04:39 AM
enibum's Avatar
Default RE: HELP Please
Hi Billy. I have a 2001 Excursion with the same front end setup you have. Mine was doing the same thing and it ended up being the bearing hub had went bad and I had to replace it. This may not be your problem but it will give you something to check out.
Old 04-19-2007 | 09:15 PM
Billyb's Avatar
thanks so much.
Hugo
07-09-2012 01:44 AM
skuntz01
09-07-2009 09:14 AM
Billyb
05-12-2007 03:32 AM
timmyers15
11-07-2006 01:34 AM
CodyAlanB5
11-07-2005 12:08 AM
