No Floor Vent Heat
Old 02-01-2008 | 07:06 AM
etrembla's Avatar
Default No Floor Vent Heat
My 1997 F250 heater/blower works fine, except I cannot get the heat to come out on the Floor (feet) area. All other vents work fine. I had it repaired a year ago and was told the "door" (plenum?)had come off - they simply put it back in place. Is there a simple way for me to fix this myself? How do I access that area? Any ideas on how to fix this would be greatly appreciated.
Thank you for your assistance!
Eric
Old 02-01-2008 | 10:30 AM
david paul's Avatar
Default RE: No Floor Vent Heat
LOOK UNDER DASH JUST ON RIGHT SIDE OF TRANSMISSION HUMP AND U SHOULD SEE IT MY 94 DIS THE SAME THING AND I PUT IT BACK ON AND CLIPED THE LOCK IN PLACE SO FAR IT HAS STAYED FASTENED IT WILL B ABOUT 2INCHES DIAMETER WITH A VACUM LINE ON THE BACKSIDE AND THE LINKAGE ON FRONT SIDE
Old 02-06-2008 | 07:39 AM
etrembla's Avatar
David Paul - Thank you!! I appreciate it and will give it a shot!
Eric
Use Common Sense
06-25-2016 01:30 PM
gmckinzie
07-10-2013 10:32 AM
Brianprimo
05-19-2006 12:26 PM
bluegoofy
08-03-2005 12:00 PM
klhaan
05-15-2005 10:32 PM
Quick Reply: No Floor Vent Heat
