oil pan bolt size (not drain bolt, actual pan bolts)
Hello everyone,
I did the unthinkable. After replacing my timing cover I lost two of the small oil pan bolts that need to come off to get the cover off. I thought I did pretty god with staying organized, but I guess I didn't. Of course it's leaking a very little right around that area.
Does anyone know what size those bolts are. They are the bolts that hold up the oil pan. I remember them being pretty small, and they are different than the two bolts closest to the timing cover.
If I could find out the size, I can try to order new ones.
Thank you!
Thank you!
You didn't post what vehicle you are driving, so I will post the bolt part number for my 6.0L ......
W300002 for the short bolts. 10 ft-lbs torque.
https://www.tascaparts.com/oem-parts/ford-bolt-w300002
jbrianfoto
09-29-2020 07:35 AM
