oil in radiator
Old 01-29-2008 | 03:24 PM
bugalooa's Avatar
Default oil in radiator
I own a 01 F-350 super duty with a 5.4 engine, I have oil in my rad and am wondering where it would be coming from???
Old 01-29-2008 | 05:17 PM
david paul's Avatar
Default RE: oil in radiator
sounds like head or intake gasket or trans cooler in radiator
Old 01-29-2008 | 07:29 PM
bugalooa's Avatar
I don't think it's the tranny one in the rad, not losing tranny fluid, think it's motor oil, lose about 1 quart of oil every six months.
Old 02-03-2008 | 03:01 AM
Level2's Avatar
I know some of the early 5.4s had problems with a gasket leak at the back of the intake. Could be crossing into the coolant stream there or you could have a cracked block or blown head gasket, although a head gasket usually causes a coolant loss.
Old 02-04-2008 | 02:10 PM
pepper97's Avatar
Do you have an external oil cooler mounted where the oil filter goes on? If so it might leak there or I believe the lines from that go into the radiator also like the trans cooler.
Old 04-13-2008 | 10:52 PM
letsfixaford's Avatar
I don't know much about the 5.4, but I had a 7.3L F-350 power stroker diesel and I was getting oil in my radiator it was because i had an injector sleeve cracked.
jcasaccio
10-07-2018 09:02 AM
fordenthusiast
12-10-2008 08:20 PM
Fordbricklayer
08-13-2008 11:14 PM
WindstarWorkHorse
02-25-2008 12:58 PM
factory310
04-28-2007 07:23 PM
Quick Reply: oil in radiator
