Question about camshaft position sensors
Hello, I have to rewire the camshaft position sensor on bank 2 due to an accident. 1 wire is solid color while the other has a black stripe, does it make a difference which side of the sensor gets the striped wire? Thanks
I'm working on a 2009 F250 with a 5.4 gas engine.
Little issue looking at the wiring diagram there is not a cam/crank solenoid/position sensor that matches the colors you mentioned.
Might I recommend posting a picture of both the location of the plug and the connector itself.
See below for cam position sensor wiring diagram.
