Ran out of diesel! Now won't crank
Old 03-09-2008 | 06:31 PM
cristieluvsherford's Avatar
Default Ran out of diesel! Now won't crank
I ran my 7.3L out of fuel and now after putting more fuel in, It still won't crank>>>> Can't find bleeder, HELP
Old 03-10-2008 | 01:29 AM
roofcam's Avatar
Default RE: Ran out of diesel! Now won't crank
TRY THIS....from someone that knows more about it thanI do. It worked for my brother.
Open the filter drain, KOEO three times for 30 sec's each, close filter drain, start engine.
The engine will run slightly ruff then smooth then stumble again a couple times while driving until the air is worked out of the fuel rails. This is normal and should resolve it's self in 5 miles or so.
If you dry cranked for a extended amount of time then you may need to bleed the fuel rails as you pumped air into the rails. There's a fuel rail 1/8NPT plug on the right front (passenger side) and left rearhead, on the slant of the head.
fisherman79
08-12-2015 03:38 PM
gkpische
11-30-2012 01:24 PM
jcasaccio
11-02-2009 07:24 AM
Doug Funny
11-01-2009 01:32 PM
Quick Reply: Ran out of diesel! Now won't crank
