rear axle seal
Old 03-04-2008 | 07:32 PM
tom37's Avatar
Default rear axle seal
I have a 95 250 with a full float rear axle. I am nearing wits end on this one. I had to put brakes on it a while back. Now I must admit my first mistake was getting the seals at O Riley. They leaked bad. Then I went to ford got the factory seals and installed. Now it seemd that I am having a leak on the bottom side of the spindle were the seal surface that has rubber on the inside slids onto the spindle. This seal came as a one piece unit that pressed in to the hub. I am just at a loss hear, I used emery cloth on the spindle, I used a light coat of oil when I installed. I guess I am courious if there is a sealer or an adheisive that may seal this problem.
Thanks
Tom
makuloco2000
06-02-2014 03:05 PM
shanes 04
06-15-2010 04:34 PM
dale55
04-16-2010 05:46 PM
bspan27801
10-04-2009 12:33 PM
tuneafish
02-10-2009 07:53 PM
