rear bumper sensors
Old 03-13-2011 | 07:37 PM
towman's Avatar
Default rear bumper sensors
i was wondering if somebody can tell me whats up i have a 2006 f250 when the truck is put in reverse the light on the sensor switch comes on.they dont beep at all checked all connections there all good.dont know if the switch is bad or it needs a new sensor or how do ya test them?
Old 04-05-2011 | 01:50 AM
1claytonb's Avatar
I'm having the same issue, I have a 2002 F350. Has anyone had an idea what might be going on?
Old 07-07-2011 | 02:30 PM
dcochran's Avatar
I started having the same problem with 2001 F250 about a month ago. The book doesn't say which fuse it would be so I don't know where to look.
Old 07-15-2011 | 11:24 AM
pwrstrokr99's Avatar
I am currently diagnosing the same issue. I start the truck and the parking sensors always illuminated "off". I have a 02 F350.
After a little research, Im starting to track down the problem.
The most common problem is a failed sensor. You can either go to the dealer and they can hook up some diagnostic equipment and tell you which has failed, or if you are like me and hate dealerships, you can try this:
Turn the ignition on, but dont start the vehicle. Put the transmission is reverse (with the parking brake on, duh). Now run back to your rear bumper and put your ear right on each sensor. You should hear a really quiet tick-tick-tick-tick-tick.....its really quiet so you wont hear it with the vehicle on. I did this last night and 3 or the 4 sensors made the ticking sound, but the far right (passenger) sensor did not. If any of the sensors have failed, the system defaults to inopperable. I am currently trying to track down a sensor to confirm this. Others on the internet say this works, I'll keep you posted.
If none of the sensors are ticking, I'd venture a guess that not all the sensors failed at the same time. This would lead me to believe that you have a failed PAM (Parking Assist Modual). And this is where my knowledge of the system ends. Still trying to figure out how to diagnose the PAM. I'll cross that bridge if a new sensor doesnt fix my problem.
Best of luck!
34mpg
01-11-2013 04:28 PM
mayt444
11-05-2009 12:42 PM
daylynn
03-06-2007 09:38 PM
joeski
North East
01-02-2007 02:28 PM
PiotrGliwice
09-23-2006 07:15 AM
