Right Front Rotor
Old 12-17-2006 | 07:29 PM
retiredlarry's Avatar
Default Right Front Rotor
Hi,
Looking for information (and sketches if available) about how to remove my right front rotor from my 1994 F-250 5.8 Liter four (4) wheel drive pickup. The hubis the automatic style.
Also, how deep can scratches be on rotor beforeit can no longer be resurfaced? Caliper jammed and wouldn't retract pads, until I heard the classic grinding noise.
Any help would be appreciated.
Thank you,
Larry
Old 12-17-2006 | 10:25 PM
wheelsup68's Avatar
Default RE: Right Front Rotor
Just jump right into to it, For the cost of the replacement rotor you should just put a new one on it anyway. You should also check for brake hose restriction causing the caliper to hold pressure(common problem) Anyway if you start to remove the hub assembly you can lay parts out in order they are removed and reinstall in opposite order.
Old 10-24-2007 | 01:02 PM
dieselfinder1's Avatar
I just had my passenger side front wheel caliper lock up on me after an emergency brake maneuver. I only noticed it after smelling odor going down highway for three miles. Thank God that I had three bottles of water with me to put out thefire! I had ownly owned the truck 15 minutes.
patioman
12-06-2007 09:45 AM
crashxnxburn
05-05-2007 02:37 AM
crashxnxburn
05-01-2007 11:47 PM
DoctorAuto
05-23-2006 09:32 PM
DoctorAuto
05-20-2006 09:23 PM
Quick Reply: Right Front Rotor
