Stciky idle
Old 06-28-2007 | 04:51 PM
racinteach's Avatar
Default Stciky idle
Well I have cleaned the throtle body valve like I should, but the idle on this truck jumps all over the place. At a stop it will sit at 1k for abit then drop to about 700 RPM..today it stayed at 1K with the AC on..is this normal?..cause it's kind of scary not having the engine help with braking.. btw this is on a 99 f250 5.4 gas ,
Old 07-04-2007 | 02:01 PM
GrampaTruck250's Avatar
Default RE: Stciky idle
If it's sticky, try adhesive remover.
Old 07-04-2007 | 02:41 PM
racinteach's Avatar
haha that was funy...lets try this again..step on the gas, idle stays high, when I step on the brake..the idle stays high, for a second, then drops from 1k to 500. In a heart beat ..there does that explain it a bit..thanks,
Olpapa
05-18-2008 04:22 PM
rippedrob420
05-29-2007 11:06 PM
