TBC Fault F360
Old 06-25-2020 | 09:33 PM
Denver Dan's Avatar
Default TBC Fault F360
I have a 2006 F-350 SRW Supercab 4WD and I am getting a "TBC Fault" on my dashboard. I hooked up my 5th wheel trailer and I get no brakes in the trailer, even when I manually pull the lever to test brakes. Brake and turn signal lights all work. The fuse isn't blown; the wiring at the plug-in adapters in the rear of the truck do not appear corroded or dirty. I removed the factor built in brake controller and disconnected the wires, and I still get the code TBC Fault. That seems to tell me that the problem is not in the brake controller. Any ideas?
Old 06-26-2020 | 08:55 AM
bismic's Avatar
Do you have a scan tool to read codes? If not, you need one. Highly recommend ForScan Lite to a smartphone or the full version to a laotop. The software is cheap (free for the laptop software). You will need an OBDII adapter though. The adapter you want depends on the device you plan to use (android phone vs iOS phone vs laptop).
The adapter can run $35 to $80. I have used the BAFX bluetooth adapter for Android and the BAFX WiFi adapter for iOS. The OBDLink MX (or MX+) products are perhaps better and for sure would get one of them for a laptop.
Having any ABS issues? Notice anything odd with your instrument cluster?
Old 08-27-2020 | 12:28 AM
Denver Dan's Avatar
Thanks for the response, things got real crazy for me shortly after I posted and I forgot I had posted on this forum.
After researching this all over the interwebs, I concluded it was a bad solder in the factory installed Trailer Brake Control 6c34-2c006-ae Tbc. There are numerous companies that re-solder the part for about $75. I was able to re-solder it myself, but I may get one to have just in case. They are over $400 from Ford.
Old 12-26-2020 | 09:06 PM
Richard Baker's Avatar
Default Tbc
I was getting the TBC light and alarm and removed the module and resoldered the problem contact 2 orv3 times, removed fuses and still had the error message. I put my 2005, F350 in the shop for brake work and State inspection. I got a call that none of my brake lights worked and the shop determined my brake light switch was bad and replaced it.
I read is some previous thread that the switch could be the TDC fault cause. Reinstalled the TBC module and WA LA no more TBC fault.
captainkirby
04-30-2020 01:53 PM
Camper
02-04-2019 12:16 AM
Mouse6196
07-01-2014 12:55 PM
Davem
04-17-2008 12:08 AM
DSmith
10-16-2006 02:44 PM
Quick Reply: TBC Fault F360
