transmissions
Old 10-17-2006 | 07:21 PM
powerstroke99's Avatar
Default transmissions
i have 99 ford sd diesel auto, o.d light flashes after 10 or more miles driven then come to stop and manual shirt from low to second then third, let truck cool down about 45mins. then ok till 8-10 miles.
Old 10-17-2006 | 11:29 PM
masterexploder's Avatar
Default RE: transmissions
sounds like you have an overheating tranny you should take it somewhere and have them scan for codes to give you a better idea of what your problem is
Old 10-18-2006 | 10:02 AM
94 4x4 ranger's Avatar
Do you have a trans cooler?
Sounds like the fulid is getting hot.
Not shure about the OD light.
_____________________________
94 4x4 ranger
Old 10-20-2006 | 12:05 AM
the tranny has a temp sensor called a TFT (trans fluid temp) and if it gets hot enough the sensor will set a code and that would cause the OD light to flash.
Old 12-14-2007 | 01:00 PM
Trester's Avatar
So if my TFT light does not flash im ok. I was told the light was for trans. codes not just temp?
Old 12-14-2007 | 01:01 PM
Trester's Avatar
Im just put a tranny in my truck and want it to last and not run too hot.
rockiesgirl
02-10-2007 05:44 PM
rockiesgirl
02-10-2007 05:43 PM
powerstroke99
10-18-2006 09:38 AM
Sanguinius
12-22-2005 05:55 AM
rwbatten
02-28-2005 08:20 PM
