Truck won’t shift
Truck won’t shift
I have a 96 f350 7.5 l auto, truck won’t drive forward unless you start of manually in first gear and shift manually... no problem in reverse. Sometimes truck will act normal but usually if you try and start off in drive it’s like your trying to start off in 5th gear or something
Some systems are designed to prevent damage with full power applied. Called Limp Mode.
Don't know if this is what might be happening, but might be a good idea to have vehicle checked for pending/ codes in memory.
If any codes are present might provide some direction as to where to start checking.
