Turning up injectors
Old 05-09-2005 | 04:36 PM
sprdty21921's Avatar
Default Turning up injectors
How do you turn up injectors on a 7.3L powerstroke?????????
Old 05-12-2005 | 02:35 AM
truckpuller's Avatar
Default RE: Turning up injectors
Since they are computer controlled and also use 115 volts to fire the injector would not mess with them. The only thing you can do is buy a chip or one of those programers to change the horsepower setting.
Old 02-27-2008 | 12:51 PM
nic7.3l's Avatar
Is there any way of turning up your fuel injection pump to get more fuel injection
Old 02-27-2008 | 12:52 PM
nic7.3l's Avatar
fuel pressure
Old 02-27-2008 | 02:35 PM
The Powerstroke Diesel doesn't have a mechanical fuel injection pump like to older 7.3's.. Injection pressure control is done with very high pressured engine oil for injector push/PSI.. The high pressure pump (HPOP) sits forward in the engines valley and injection pressure in relation to throttle angle is controlled by the PCM (non adjustable).. As is PCM control for 'pulse width' or amount of fuel/time the injection event takes place.. Fuel pressure is non adjustable as well and is a return to tank system.. As truckpuller stated,, the easiest way to build good power with a PSD is a chip/box, or programmer.. Also intake and/or larger exhaust help too, more so for the higher HP tunes..
Old 02-27-2008 | 03:06 PM
Pre Powerstroke? What year truck?
boomerfocus
10-13-2006 11:54 PM
96cvpi
03-28-2006 02:45 PM
FordTough
01-29-2006 10:30 PM
huntingsmoke74
09-11-2005 07:13 PM
Joe Blow Racing
11-30-2004 12:29 AM
