water seperator drain
Old 04-21-2007 | 09:57 AM
dee004's Avatar
Default water seperator drain
I need help locating the valveon the water seperator 05 6.0 F250. I found the FCM under the left side of the frame. Is the drain the quarter size plug in the end of the unit with the hex/allen key. The picture in the manual shows a fip lever but this one doesn't have one. Want to drain it regularly before the light comes on or before it's too late. Thanks
Dee
Old 04-21-2007 | 02:50 PM
Default RE: water seperator drain
That's it..
You can convert it to one off the LCF trucks.. It's a thumb screw type for easy removal without tools, and still has theallen hex as well.. Also has a hook that keeps it in place when removed and helps to 'wick' draining fuel away from the frame rail...
[IMG]local://upfiles/6756/6AA5C4E70F0D444F9A0A5510F6D7E533.gif[/IMG]
[IMG]local://upfiles/6756/9C6DB1A95F03446F84D7D269D5CA4AF5.jpg[/IMG]
Old 04-21-2007 | 06:23 PM
dee004's Avatar
Thanks Hayapower. Your a great help.
craigatkins
03-19-2007 05:37 PM
Brianprimo
05-19-2006 01:26 PM
RNGMSTR
02-24-2006 08:47 PM
Kronos
06-18-2005 01:24 AM
tbbucanrs
05-04-2004 01:35 PM
