What's that clunk, clunk sound?
Old 10-24-2010 | 10:47 PM
ptotoole's Avatar
Default What's that clunk, clunk sound?
2000 ford f250, superduty, powerstroke
Turbo charged. Super cab, long box. 4 wd, 6 speed manual with floor shift. Very large truck, new tires.
When driving down a street or road, at every bump in the road, the suspension or something makes a clunking noise. It only makes that sound when driving over bumps.
I never noticed it until others pointed it out. It seems to be coming from the front end of the truck.
Could it be a problem with the suspension, shocks, wheels out of align?
I don't know what it is, or if anything is wrong. Its a large heavy truck, I thought it was just wheels bouncing.
Is something wrong with suspension, shocks?
Thank you
Pat
Old 03-11-2016 | 02:22 PM
scebrandon's Avatar
Default I have the same problem!
Did you ever get a response about this question? I have a 2002 F350 that seems to be doing the same exact thing!
Old 03-11-2016 | 06:02 PM
Sometimes you can find something loose or worn by just looking under the vehicle and trying to move things by hand.
Old 03-13-2016 | 09:48 AM
eric hoffmeyer's Avatar
Could it be the coil springs wiggling a bit in their mounts?
Old 03-14-2016 | 01:07 PM
Alanah_Rae's Avatar
Welcome on a board !!
Old 03-23-2016 | 01:38 PM
LakelandFordParts's Avatar
Former Sponsor
You will need to get that vehicle on a lift and have a steering/suspension inspection preformed. If you need help locating parts please let me know.
Old 10-23-2017 | 08:13 AM
perfectlift-tips's Avatar
Usually a vehicle makes a noise if it has loose bolts or some parts. Just give a visit to the local car mechanic, it will surely help you resolving the issue.
Old 11-30-2017 | 10:44 AM
Ghostrider33's Avatar
Default Clunk
My 2011 F350 does the same thing.
I found the 2 forward body mount bushings deteriorated.
They don't look bad on the outside but when squeezing them I found that the inside is totally deteriorated and falling apart.
billj818
10-23-2017 08:14 AM
kharlanov
12-05-2012 11:26 AM
cscottyn.1
10-31-2006 06:47 AM
msm20032003
03-25-2006 04:40 PM
auctioneer
10-19-2005 11:25 PM
