wiring on AUX switches 2005 SD
Does anyone know where the wiring for the 4 Aux switches on a 2005 Super Duty ends up. The switches are wired and the wiring goes into the wiring harness. Don't know where ends wind up. I have been to 3 Ford dealers and they can't tell me.
RE: wiring on AUX switches 2005 SD
Take the four tem mm bolts out of the fuse box under the steering column and lower it. You will find four wire ends bundled together that go to the upfitter switches. Two of them are 30 amp and two are 10 amp. If you need more info on them let me know.
dadsmad
03-02-2007 12:25 PM
dkimbro
06-29-2005 02:15 PM
