ABS Speed sensor ford five hundred
Old 09-26-2015 | 01:01 PM
horton871's Avatar
Default ABS Speed sensor ford five hundred
Hello, I have been working on a 2006 ford five hundred with about 100k on it, se model front wheel drive. Started off putting lower control arms, hubs, and front tires. Now it set a check engine light for invalid communication with abs control module, a code for front left speed sensor, a c1296 code, and a service brake system light. So I put the front left speed sensor in it. That still didn't turn the light off so i pulled it back apart. The front speed sensors look like they should be specific to each side because of the way they fit. I have looked up multiple brands and they all list the same part number for both sides. Anybody else dealt with this?? thanks
Old 09-26-2015 | 07:20 PM
primem's Avatar
are the bearings a sealed hub and bearing assembly or a press in bearing with a separate press in hub?
If its press in style, was the bearing installed in the correct orientation...tone ring side next to the wss pick up?
Old 09-27-2015 | 07:07 PM
horton871's Avatar
they were a sealed hub.
topless69gt
03-15-2016 04:32 PM
JayR101
03-18-2013 07:06 PM
ramossilver
05-09-2010 01:18 AM
DCDave
12-01-2006 11:11 PM
gaypat
10-10-2005 12:35 AM
Quick Reply: ABS Speed sensor ford five hundred
