Ball Joint or Control Arm
Old 02-07-2017 | 12:58 PM
joe645's Avatar
Default Ball Joint or Control Arm
I have a 05 Ford 500 LTD and have found the right lower ball joint has some wear and movement. Is the BJ replaceable or do you have to replace the entire control arm?
Old 03-05-2017 | 08:05 AM
daveyboy8's Avatar
i have an 06 and pass side was worn. had to replace entire control arm. was not hard to do if you are mechanically inclined. took about an hour. good luck!
Old 03-05-2017 | 09:58 AM
primem's Avatar
i don't see a replacement ball joint; only control arms. the price for the ca is pretty reasonable.
http://www.rockauto.com/en/catalog/f...trol+arm,10401
primem
02-12-2012 10:17 AM
shel67
10-13-2010 06:32 PM
cobra--x
02-21-2010 07:40 PM
shel67
09-22-2006 04:26 PM
DYI
03-29-2005 12:54 AM
