Diagnostic Code P061B & P2106???
Took car to Auto Zone and got two codes, P061B and P2106. The man didnt know what the codes meant. Can someone please explain what this means car has been acting up lately and it's driving me insane!!
Thanks in advance.
Thanks in advance.
Codes don't tell you what is wrong
Okay... sorry for being gone so long. The problem was fixed once I convinced the dealer that pulling the heads was the wrong corrective action. They finally found a broken wire to the #4 injector, causing what the code says as a too lean of a mixture (ergo, why they thought it was a valve). Fixed wire, problem solved. Driven to Charleston and Boston with no repeat, no problems. Great little car, now!
Yes...your throttle body needs to be cleaned out..it is very simple and only takes a few minutes...my car has done the same thing..I have an 06 Freestyle with 95000 miles on it...You do have to continue to clean it out every so often though but it saves you ALOT of money at the dealership. GOOD LUCK!!
Boilerbob30
02-11-2013 10:07 PM
