Fuel coming out of the Air Intake box and snorkel
I have a 2006 Ford Five Hundred SEL 3.0 with just over 95,000. Recently I replaced the Fuel pump, Fuel Pressure sensor, Thermostat, Thermostat sensor, and fuel filter. I am still having issues with the car not wanting to start at all. When I went outside today to troubleshoot more I noticed a strong smell of gasoline coming from the engine. I was looking and looking but could not find it till I got near the air box. I opened It up and noticed the air filter was soak took that out and there was gasoline in the bottom of the air box. I removed the Air Box and Snorkel from the car and inspected it along with the throttle body I did not notice any gasoline on the throttle body but when I turned the air box and snorkel over gasoline poured out of it. It was coming from that box that hangs below the snorkel itself. Any Idea what I should be looking for extra? It would be a great help
What you saw today could be a result and caused by the parts you replaced recently and crank no start could be another issue. All the parts you changed recently you have to make sure they were replaced correctly, you just have to go back and double check.
I have gone over the steps that everyone has suggested, I went through the work I have done, and I recently changed the throttle body out knowing that those were recalled years back and even had problems. The car did not want to start then, so I let it sit for a few days went out it fired up right away on the first try but it was running super rough, and blowing black smoke out the tailpipe. I am at a loss of what it could be as several codes were thrown.P0182, P2196, P2198 P0183, P0193, P0302, P0316, P1000, P0106.
My first suggestion would be to, disable the fuel pump, and run a compression test. If there is any type valve problem, it will show there.We need to know where we stand with the mechanical parts of the engine. If you can get that done , provide the readings and we can go from there..
Any other way is MORE shooting in the dark and is not smart. Can you do this ?
