Intermittent instrument cluster
Old 03-26-2013 | 06:14 AM
rosiegirl's Avatar
Default Intermittent instrument cluster
I love my Ford 500. But recenlty the dashboard lights are flickering. I took it in 3 times and there was no reading on the computer. Finally - today a reading. Intermitten ..800.00 help me. I am underemployeed...Monroe mi
TSB 06-17-9
09/04/06
INTERMITTENT INSTRUMENT CLUSTER
OPERATION - INCLUDING GAUGES SWEEP/RESET - MULTIPLE WARNING LIGHTS ILLUMINATED AND/OR REVERSE LIGHTS STAY ON - VEHICLES BUILT BEFORE 2/17/2006
FORD:
2005-2006 Five Hundred, Freestyle
Old 03-27-2013 | 09:44 AM
rosiegirl's Avatar
How long can I drive like this?what will happen? This cost if horrible! 500.00 part cost plus labor.
Old 03-27-2013 | 04:10 PM
Chances are they will replace your defective unit and send your unit out for repair and you never know it could be to the same place as posted. It's not good to continue to use it as it is.
Old 10-01-2022 | 07:23 AM
Shuntsman23's Avatar
My mom has a 2005 Ford Five Hundred 40k miles And the back up lights were on when in park or driving. And the dash lights did not come on. They replaced the battery and alternator. And a week later the car won’t start now. It makes clicking sounds when you turn the key. It has been connected to the computer 3 times and shows no codes.
Old 01-05-2023 | 10:26 PM
Harold Reyes's Avatar
WEAK solder joints on the back of the instrument cluster. Remove it [if not mechanically inclined, hire a shop to do it], it is easy!!! Carefully peel plastic away for access, and with your soldering gun, solder the joints real good L and R sides. make sure no gaps on the sticks. Take your time!!! Will clear up any cluster issues, hopefully.
rrommer
10-01-2022 07:24 AM
tootie
10-01-2022 07:22 AM
Glen Bailey
10-01-2022 07:08 AM
usmarine0905
10-01-2022 06:50 AM
02bulllx
04-01-2007 09:46 PM
