keyless code????
Old 08-28-2006 | 10:51 PM
derekjett's Avatar
Default keyless code????
Where do i find the factory keyless entry code on my new (used) 500???
Old 08-29-2006 | 12:50 AM
94 4x4 ranger's Avatar
Default RE: keyless code????
[sm=welcomesign.gif] Not shure but try the glove compartment box for a sticker.
Old 08-29-2006 | 03:36 PM
Mulletman's Avatar
You might have to take it to a Ford dealer so they can retrieve the code with the computer. It may cost around $60.00 to do it though.
Old 03-03-2007 | 10:27 AM
cobra79's Avatar
I think it is located on the module .
Old 07-05-2007 | 12:15 PM
95electricblue's Avatar
I'm going to look for my code tonight. Did you find your code and if so were? I have a 2006 500
Old 07-06-2007 | 03:05 PM
No luck finding the code. Under dash both drivers and passengers between the front and back doors. No luck please help Ford has gotten more then enough of my money and they do not need the extra $60
Troy
Old 07-19-2007 | 01:33 AM
john412's Avatar
Not sure if it is in the same spot, but on the freestyle(same platform) it is behind the fuse box. You have to look under the steering column and remove the three nuts that hold the fuse box. Don't unplug cables, just move the box so you can see behind it with a mirror. You should see the 5 digit code. Hope this helps.
Old 07-19-2007 | 11:11 AM
techmanbd's Avatar
I have also read before, in cars the number is in where the spare tire is. Not sure, but wouldn't take much to check out.
Old 10-17-2007 | 07:28 PM
RHNiles's Avatar
Never mind all the drivel I just posted, I didn't notice the year posting wasn't this year! Sorry
If you know the dealer from where it was purchased new, they will have it in their files on the car. There is a factory combination that works and overides the customer set code. If the person who had it before you set a code you will need that factory code to clear out the previous one and set it to your own code. The car will revert to the factory code anytime the battery power is turned off for any reason, so the dealer should give you the code with no problem. Also the factory code will still work even if you have set your own code, so it would be a good idea to try to remember it also.
Rick
Old 01-25-2009 | 12:23 AM
sonny32's Avatar
This is for all those who want to know,,(as I did) The code for the KEYLESS door opener,is located on the INSIDE of the cover over the CONTROL MODUAL,,(COMPUTER),, which is located under the dash in front of your left knee,(as you sit in the drivers seat)...
Good luck taking off the cover it is a real pain,,, but you my be able to just take out the 2 front screws ,pry it down and use a mirror... Good luck to all..
sonny32
