Tail Light Troubleshooting
Old 07-18-2010 | 04:14 PM
RetiredNavyGSCS's Avatar
Unhappy Tail Light Troubleshooting
Got pulled over last and was issued a citation for not having any tail lights. Had not noticed this before now. I made it to my driveway and I checked all my lights. The headlights, parking lights are illuminated. The turn signals and flashers work front and back. When I put the vehicle in reverse, the backup lights work. However, can not figure out why the running lights (tail lights) or the license plate light will not illuminate. The bulbs are fine and could not find a fuse on the fuse panel that corresponds to the tail lights. Anyone else experience this or know what I'm missing here. Thanks for the help!!
Old 01-25-2011 | 01:25 PM
langrehr's Avatar
Default bad tail light
Any luck with getting this issue resolved? I am not experiencing the same issue with my 2000 Expedition.
I can't seem to find any solution on the Internet.
Thanks.
Old 01-25-2011 | 02:21 PM
Generally the tail lites are fed from the headlite switch so they operate with the lite switch in any on position. I would suggest you start from the rear of the vehicle and check the wiring that you can see for a cut/severed wire or possibly a poor connection where the wires have a plug connection. This can be time consuming or you could hit it quickly.This is most likely what someone else will need to do in order to find the break in the circuit. If you have to pay someone by the hour it can get expensive.
Old 02-02-2011 | 06:52 AM
MobileAlabamaFan's Avatar
Default Found problem to lack of running lights
Wow! This seems so long ago and I actually had forgot about it until now. I should have posted after I found the answer to my problem to my tail light problem on my 2006 Ford 500.
To be on the safe side (or to do the simplest thing first through the process of elimination), I replaced both left and right bulbs. There was no change and the problem persisted.
I then read and studied the fuse section of the owner manuals for any clue to the possible fuse for the running lights. What I found was the fuse for the running lights is not clearly marked but is tied into Fuse Location F8, a 15 amp fuse listed as Park Lamps, Side Markers, Trailer Tow Protect. This is listed in the Passenger Compartment Fuse Panel on Page 196 (for 2006 Ford 500 manuals).
Even though the 15 amp fuse seemed fine, I still replaced it and the Tail Running Lamps were restored.
Hope this helps! Michael in Mobile AL on Wednesday 02 Feb 2011
ronfeilen
08-04-2008 10:02 AM
nuccatree
03-21-2008 07:17 PM
sootman73
11-02-2007 09:31 PM
Johnny Faster
08-27-2007 07:13 AM
daveranger
06-29-2007 01:07 PM
