2000 Focus Electrical Problem
Old 02-10-2007 | 02:05 PM
abbazabba's Avatar
Default 2000 Focus Electrical Problem
My 2000 Focus just died mid-turn the other day. I couldn't get the car to crank. I hear a clicking under the dash. I have no window power and the shifter is locked. Radio works, lights work, door locks, etc. Also when I tried to jump it I could not get a spark from the chassis. I've heard a lot of people changing their ignition switch and the starter solenoid, or the relay. I do not have a problem turning the key as many other people have had. I also just recently brought the car to ford for the pinch bolt recall on the battery.
Old 09-04-2007 | 11:36 AM
jorgeleonb's Avatar
Default RE: 2000 Focus Electrical Problem
maybea main fuse.......if you hear a click the basic circuit is working...possible the problem is in the high rate fuses......
Old 06-26-2008 | 02:04 AM
robinson1212's Avatar
kinda the same thing, but when you try to start and hear clicking does ur basical electric stuff work (radio, lights)
if so try this below. mine when i have this problem it will click a bunch of times and the radio works but wont start.
start carying a hammer or mallet... (i have the same thing) tap on the red side of the battery with somthing.
it will start.. was at intersection w/ red light on main st. sherrif's car next to me my car did the same thing.
i had to pop hood and do this. i dont know why but its like its not getting a good connection.
BTW i took this to wal-mart and had battery end replaced it works find so far.
Old 10-04-2008 | 05:16 PM
mrHowros's Avatar
Check out the website http://fordfusebox.freehostia.com
willijimon
10-21-2018 09:07 PM
FranzSanchez
01-18-2009 01:40 PM
wendywoo92
01-02-2008 01:19 PM
afloyd
10-24-2006 12:18 AM
bwilson3
10-09-2005 03:41 PM
