2003 hatchback unlocks when using the rear wiper
Old 09-28-2021 | 01:28 AM
2003zx5's Avatar
Default 2003 hatchback unlocks when using the rear wiper
2003 ZX5 Hatchback
When turning on the rear wiper the hatch unlocks (I hear the pop and see the door ajar light come on).
This started almost three months ago. It happened after having a heavy portable air conditioner (for a house) in the trunk/backseat for a few days. It also happened after unscrewing the middle (top) brake light and screwing it back in (was told it wasn't working by the shop, decided to replace it myself, then discovered it's not an easy bulb replacement but requires replacing the entire assembly. On a visual check the right most of the three lights of the middle brake light is still functional.).
I'm not sure whether the portable air conditioner pressing against the rear hatch, or the unscrewing and rescrewing in of the brake light ultimately caused this. According to a person on a UK forum such electrical issues aren't that uncommon with the original UK Focus: https://www.fordownersclub.com/forum...comment=295661
Any instructions or tips on how to fix this without taking it to a shop? Any ideas on what this would cost to fix if I did take it to a shop?
Thanks.
Old 10-11-2021 | 10:12 PM
scott.butler4's Avatar
I would recommend removing the liftgate trim panel and inspect the wiring harness for visual damage.
mark0359
10-04-2020 02:38 PM
oldad
03-12-2018 12:33 AM
sydnemo66
04-13-2011 01:08 PM
Cmarotta870
02-27-2009 08:05 PM
sweatpantstom
08-18-2007 11:03 AM
