2004 focus tranny wont go into gear!!
Old 02-05-2013 | 11:45 PM
whayewkno's Avatar
Default 2004 focus tranny wont go into gear!!
hi im new to the forums... hi everyone!!!.. ok well here is my problem. I got a 2004 ford focus 2.0 with a auto tranny... the car shifts into drive perfectly but when I go to drive I give it gas and it acts as if its in nertraul so therefore the car wont move at all ? anyone know what the problem is?? car only has 75k miles on it thanks!!!!
Old 02-06-2013 | 04:10 AM
Something you should check.
The fluid level in the trans and have someone move the shift lever while you look under the hood to make sure the shift cable has not broken or become disconnected. Look on top of the trans for the cable or just observe what is moving and that nothing has become disconnected.
Old 02-06-2013 | 11:05 AM
whayewkno's Avatar
Ok I will check when I get home thank you!! The cable is black? And has like a circle hook on it?
Old 02-06-2013 | 05:20 PM
Sounds like you found it, but you didn't say if it was connected to anything or was it just moving around?
hdiaz
09-01-2009 11:07 PM
oberding
09-25-2008 01:37 PM
sandytedder36
11-01-2007 12:37 PM
silverT1000
05-03-2007 01:51 PM
danny88
10-29-2006 02:04 PM
Quick Reply: 2004 focus tranny wont go into gear!!
