headlights pulsate
headlights pulsate
I have a 2000 Ford Focus LX. I bought it used with high miles (162K). Since I have had it, the alternator/battery warning light has been on. I recently replaced the alternator and the light still stays on. Alternator checks out fine. Since replacing the alternator I have notice that when the vehicle is cold the light goes off for about 15 miles, however, when this happens, the headlights pulsate. I have seen in chats there are many electrical issues. Any suggestions on this one?
Usually the pulsating is caused by a voltage regulator problem. Not serious , but annoying . Depending on how the alternator was checked may not show the voltage regulator problem. Best cure is a Ford remanufactured alternator. You may notice that many times I suggest rebuilt starters and alternators from a Ford dealer. All alternators are not the same even with the same model car. If there is a starter / alternator rebuild shop locally, they should be able to correct the problem with your vehicle's alternator. It is best to wait until your original alternator is repaired . Then everything goes back together quickly.
I am sorry to say that I am not positive as to whether the computer controls the output for your Focus' alternator. Will try to get the answer for that.
01, alternator, alternators, focus, ford, good, headlights, high, miles, original, problems, pulsating, rebuilt, regulator, voltage
