NOISY BRAKES
![Default](/forum/images/icons/icon1.gif)
MY 2005 FORD FOCUS WAGON'S BRAKES MAKE A LOUD WHISTLING SOUND WHEN I APPLY MY BRAKES. I WAS TOLD THIS IS NORMAL!!! CAN SOMEONE TELL ME IF THIS IS TRUE? IT'S VERY ANNOYING. THE PROBLEM STARTED ABOUT 8000 MILES, THE DEALER CHANGED THE BRAKE PADS AND TOLD ME THAT THE ROTORS ARE VERY THIN ON THE FOCUS. THE PROBLEM DIDN'T GO AWAY. I DON'T THINK THIS IS NORMAL, AND HOW AM I SUPPOSED TO KNOW WHEN I'M REALLY HAVING A PROBLEM WITH MY BRAKES. I GUESS BEFORE IT'S TOO LATE AND WILL COST A FORTUNE TO FIX OR WORSE. PLEASE HELP![Wink](https://www.fordforum.com/forum/images/smilies/wink.gif)
The most common place where i've heard the brake noise if from the rear drums. All I did was get a can of brake cleaner, put the plastic tube extension right in between the outside and inside part of the drum and sprayed away. Gone pretty easily. Oh yeah, i took my wheel off and rotated the drum around also.
ORIGINAL: hockeyhitman69
is it coming from the front or from the back the rear has a tsb that you add weights to the back of the backing plate to stop the squeal.
(Had to SHOW the service writer the TSB, though, He didn't have a clue.)
LINDADIPIETRO - I can fax (or maybe e-mail the TSB to you. Send me a PM.
nickinma
10-23-2006 02:51 AM
