Proper ATF
Old 08-03-2018 | 07:58 PM
David A. Pikul's Avatar
Default Proper ATF
Can I use castrol Dex/Merc on my 2004 Ford Focus manual transmission instead of the Motorcraft which is $24/per bottle?
Old 08-04-2018 | 09:11 AM
Check your owners manual I believe it specifies this spec for 5 speed manual trans, WSD-M2C200-C .
If the container says the lube meets that spec, it should be OK.
tracydasilva
07-08-2018 08:47 AM
2nd mustang
09-25-2011 09:06 PM
farmer45
06-05-2011 01:29 AM
rj22857
05-05-2008 07:02 AM
brytersward
01-09-2006 09:30 PM
