Weird Electrical Issue
Old 10-27-2009 | 05:41 PM
H0meIsEverywhere's Avatar
Default Weird Electrical Issue
I have an '03 Ford Focus that was recently given to me by my father.
The battery light in the focus has been on for nearly a year. He had the battery and alternator both replaced at Sears in April of this year. It has been driven various distances without stalling since then - and when I received the vehicle a week ago I set about to try to fix the car completely.
I ran a test on the car and found the battery to be fine but only 12.1 volts coming out of the battery (tested at the B-terminal of the alternator) I returned the car to sears as the alternator was still under warranty - have now been through 3 remanufactured alternators (all of which read 12.1 volts of output as soon as they are installed.) I have tested all the wiring leading from the alternator to the battery - the fuses - took the 3 prong off the alternator and tested that - everything points to the alternator being the problem.
And yet, every time I put a new alternator in... it outputs only 12.1 volts.
This is driving me nuts and if anyone has any suggestions or has encountered similar problems, ANY help is appreciated. Thank you!
theunpaidBill
01-05-2014 09:26 PM
MrAndy1369
06-10-2013 11:27 PM
ludwikowski02
09-26-2012 10:32 PM
droz
01-15-2012 01:41 PM
atypclengr
01-14-2009 04:15 AM
