When Can I change the timing belt!!! And Engine Bay Photos
Old 05-08-2007 | 07:27 PM
dntcare's Avatar
Default When Can I change the timing belt!!! And Engine Bay Photos
Hey... I was wondering at what mileage on the car should i change the timing belt... and where can i locate the engine bay wiring photo...
Old 05-11-2007 | 07:13 PM
william1234's Avatar
Default RE: When Can I change the timing belt!!! And Engine Bay Photos
90k also do a water pump as well
Old 06-21-2007 | 04:46 PM
AcBPimpin's Avatar
My 2002 ZX5 is at just under 75,000 and I'm getting ready to change the thermostat, timing belt, and water pump. Not that it's all going bad or anything but if the timing belt goes out on these Zetec motors your replacing the motor. Mine just recently quit holding water so I'm going to go replace everything to make sure its all good, and at a do it yourself price it'll cost about $120 through Auto Zone
Old 06-22-2007 | 07:13 PM
detroitmi's Avatar
I believe the timing belt replacement interval is either 100k or 120k. It does not hurt to do it earlier and make sure you use a quality belt. Dayco, Goodyear and the sort. And as mentioned before, chanage the water pump because it's only a few dollars more. Always remember to change the fuel filter as well every 30k to 50k. Fuel filters are the most overlooke and important maintenance items.
Wentworth Miller
08-24-2012 04:50 AM
NickTurbo
04-01-2012 10:21 AM
FIRE RANGER
12-06-2009 02:17 PM
Qaiphyx
04-04-2008 12:59 PM
95se_mexican
12-16-2006 08:58 PM
