1968 Ford F-100 Shortbed info needed?
Old 12-06-2013 | 02:59 PM
bicyclecharley's Avatar
Default 1968 Ford F-100 Shortbed info needed?
Just drove my new F-100 from N. Carolina to Texas and developed an oil issue. Before pulling the motor I would like to know the specs on a compression check? Was told that 40, miles ago the 306 inline eng. got bored out to 30 over, with new rings an bearings an such. Need to know the #"s I'll need to see with compression check? Anyone know?
Old 12-06-2013 | 05:21 PM
grindman's Avatar
at least 125psi or higher
Old 12-09-2013 | 01:53 PM
Default 1968 Ford F-100 core support?
Where could I find an aftermarket core support(front radiator support)?
Mine is needing replaced an would rather replace than weld a bunch of new metal, but can if I can not locate new.
Thanks for all leads?
Have a few pics on my facebook/bicyclecharley if ya wanna look at this fine 68 shortbed!
Old 12-09-2013 | 02:30 PM
grindman's Avatar
LMC truck is a good place for a new one cause I don't about any salvage yards where you live. and besides you probably want one for a V8 so that new rebuilt motor doesn't get too hot with it being bored out the cylinder walls ain't as thick and can't take a lot of heat. finally you have one of the best engines Ford ever built those 300 inline six's are one tough motor and are known to give service for a long time as long as it's well maintained and not neglected much.
cburcell
02-10-2013 09:38 PM
mrdcpl
11-03-2008 09:20 PM
puresnowchic25
03-05-2008 08:55 PM
ck_russell
10-11-2006 01:13 AM
forddriver72
01-13-2006 07:32 AM
