1999 f800
When I had an odd set of circumstances with a Cummins unit I checked with a factory authorized service location and they were usually cooperative and would provide info like you are needing. Most Cummins had a diagnostic plug for scan tool use located at the left side of the steering col.just under the edge of the dash above the clutch pedal.
1999 f800
Hello, did you ever find your obd plug? I have the same model and year truck and I can’t find mine either
mavric460
11-12-2010 12:16 PM
mavric460
07-21-2010 07:48 PM
