1999 Ford Contour
1999 Ford Contour
When applying the brakes, the left front of the car pulls to the right if the car is traveling approximately 35 miles per hour or faster. Also when backing out of a parking area, sometimes there is a grinding noise coming from the left front wheel. I've had a front end alignment, new brake shoes and pads, Sears can't find the problem. I NEED HELP!!!!!!!!
[quote=Mary Washington;64516]When applying the brakes, the left front of the car pulls to the right if the car is traveling approximately 35 miles per hour or faster. Also when backing out of a parking area, sometimes there is a grinding noise coming from the left front wheel. I've had a front end alignment, new brake shoes and pads, Sears can't find the problem. I NEED HELP!!!!!!!Can someone provide me with a solution to my dilemma?]
