Ignition problem Ford freestar
Old 03-13-2011 | 07:01 PM
undermi1's Avatar
Default Ignition problem Ford freestar
2004 Freestar died in the rain. No spark to the plugs. replaced coil and Crankshaft sensor and still no spark.
Put test light on Connector to coil and the Red wire has power, but other three will not light the light when turned on, or Cranked.
Any ideas?
Old 03-13-2011 | 10:53 PM
Signal goes from crank sensor to PCM, to ign module then to coil. Sounds like it could be ign module or PCM.
Old 03-14-2011 | 09:26 AM
undermi1's Avatar
Thats good to know..now..where is the IGN Module? I can not find it listed as a part on this model...
Old 03-14-2011 | 12:35 PM
Those modules don't come cheap. Would advise having vehicle checked by someone with proper equip before spending anymore $.
Old 03-15-2011 | 10:48 AM
undermi1's Avatar
Thnaks for sharing that thought, unfortuantely my Mechanic must not have the prioper equipment. What would be the proper equipment?
Old 03-15-2011 | 11:11 AM
Rest assured your Ford dealer has it.
Old 03-15-2011 | 03:47 PM
undermi1's Avatar
no offense, but if I wanted Ford to diagnose it for 500.00 I wouldn't have taken the time to post on here. I thought the whole purpose of these boards are to share knowledge and wisdom and not shill for the dealer
Old 03-15-2011 | 04:08 PM
I agree with you ! However, when you realize what you're dealing with, is it not wiser to get the job done with the right equipment. Speaking for myself , you can't keep throwing money at a problem hoping it will go away. If every time someone said change this or that they are spending your hard earned $ and there are no guarantees. There just are some diagnosis that cannot be made over the internet.
artkur
05-31-2013 07:56 PM
krazydawg40
03-28-2007 05:58 PM
bighueyy2k2
10-12-2006 11:58 PM
riska720
10-26-2005 05:20 PM
highpowerd2003
08-29-2005 11:56 PM
