t-5 trans install ?
t-5 trans install ?
Hope im in right area ? if not please tell me where to go, my wife does all the time . I took a 3 sp standard trans out of my 1931 ford roadster , im wanting to put a t-5 trans back in . Sold mt bowtie and am coming over to the blue oval camp now. Have a few things i need help with,I have a 289 with 302 heads ,1969 block 1968 heads , All i see for bell housings are for a tremmec transmissions ,will the t-5 fit this bellhousing ? , Is my 69 289/302 the same bolt pattern as a 5.0 motor ? , if so what year bellhousing would i use if diffrent ? . I also see two diffrent weight flywheels for 302s ,28 oz and 50 oz ,i got rid of old set up befor i had a chance to check it out . Also i see tw0 diffrent counts on flywheel teeth , does that have to do whith clutch size ? sorry to go on and on but give me credit for not putting a sbc motor in a ford ,i hate that . I guess i could have just asked what bell housing and weight flywheel to use to install a t-5 behind a 1969 289/302 motor sorry
conanalois
08-31-2013 07:16 AM
