2004 Freestar AC compressor?
Old 10-13-2013 | 12:21 PM
mayday13's Avatar
Default 2004 Freestar AC compressor?
I have a 2004 ford freestar sport 4.2L I recently had to replace the serpentine belt as the old one snapped. It ran well for about a week now there seems to be a noise coming from the AC compressor and the pully "wiggles" when I try and move it with my hand. When the original belt snapped there was smoke coming from the pully area of the AC but I chalked it up the belt rubbing on the pully after it snapped, but am rethinking that now. when I turn on the ac when the van is running the rpms drop and occasionally when turning into a parking spot the van will stall.
Any ideas?? I am guessing something with the AC unit is affecting everything?
Thanks
Old 10-15-2013 | 03:30 PM
Penguin98's Avatar
Sounds like the pulley bearing is bad...
Check with the OEM dealer for a new one, should be an easy fix
http://www.bluespringsfordparts.com
Old 10-16-2013 | 04:59 AM
Use Common Sense's Avatar
Actually sounds like your A/C compressor is siezed. I would try to see if you can turn the compressor by hand. A siezed compressor will cause the belt to smoke as the pully won't turn when the compressor clutch is engaged. It will also cause the engine to stall as you described.
romeodz
07-12-2014 03:08 PM
carterl5
11-09-2013 04:05 AM
stainlessguy
10-19-2011 08:32 AM
gmingst
05-23-2011 07:42 AM
mdeboer
09-25-2009 07:37 PM
Quick Reply: 2004 Freestar AC compressor?
