2005 Freestar AC drains
Old 06-30-2011 | 03:30 PM
vdotmatrix's Avatar
Default 2005 Freestar AC drains
I have a manual but I cannot find where these drains are located. I always would see water from the A/C coming from the front of the car and from the rear during the summer months....this year I am a little nervous that I don't see this and I am afraid I have a blockage but can't find where the drain holes are.
can someone please show me where to find these guys so I can possibly unplug if needed.
Old 07-05-2011 | 07:56 AM
Use Common Sense's Avatar
The drain for the rear is between the HIGH and LOW pressure lines where they enter underneath in the rear left side of the van. Not sure of the front, never looked for it. What's the humidity level where you're at? If running on MAX, and low humidity, you will normally see very little if any water coming out. Plus, the londer your air runs on MAX, the less and less water that will come out as the moisture is removed from the air inside the van.
Old 07-22-2011 | 01:33 PM
bgailitis's Avatar
It is right under the connection for the Orifice tube
makuloco2000
12-31-2013 02:33 PM
jhcantwell
11-11-2010 05:41 PM
jim333
04-07-2008 08:54 PM
ck
03-06-2008 05:12 PM
ck
03-06-2008 12:47 PM
