2006 Freestar Acceleration Issues
Old 03-14-2012 | 09:37 PM
adamcpennington's Avatar
Default 2006 Freestar Acceleration Issues
I have an '06 Freestar with the 4.2. I recently replaced the MAF however I'm still having a horrible issue with the vehicle where when I try to accelerate the engine almost dies. It seems to be choking itself out. It is throwing a code of PO108. Does any one have any ideas on what this could be or where to begin?
Old 03-15-2012 | 03:19 AM
Use Common Sense's Avatar
P0108 is for the MAP sensor. Did you replace the MAF or MAP. I believe that the MAP is part of the EGR assembly (not 100% sure). If it is, I would check the connector, voltage output and vaccum hose(s) connected to it to ensure that they are OK.
avopy
02-20-2015 09:13 AM
Transit04
02-03-2014 02:09 PM
levittm
03-16-2011 06:56 PM
peters04mn
08-20-2010 11:22 AM
yar89
04-22-2008 01:00 PM
