brake issues 2005 Freestar
Old 11-30-2008 | 01:06 AM
tuneman's Avatar
Default brake issues 2005 Freestar
Hey all, I put new pads on my wifes 2005 Freestar and had a heck of a time collapsing the rear pistons. I know they turn and I finally got them but I was unabe to do so on the vehicle. Unfortuneatly, a simple job turned in to a big P.I.T.A. on my only day off!
OK the pads are on it's back together but I know that I now must bleed the brakes. So I did so and have bled the brakes on many, many vehicles over the years with no problems until now.
The problem being that i can't get the pedal to come back after multiple tries at bleeding right rear, left rear, right front, left front. Turn off the van and it's hard. Start it up and it goes right down. If you hit it twice with the van runningthe second pump will start to bring it off the floor but the third try and it's right back down.
Something is telling me that there must still be air in the lines but I am not sure if it's that or something else that i have no idea about.
Any help to set me in the right direction would be greatly appreciated as I have to get this thing going ASAP....... Thanks much, tuneman
Old 11-30-2008 | 01:54 AM
Default RE: brake issues 2005 Freestar
During the caliper removal, or during the bleeding did the master ever run dry?
Old 11-30-2008 | 11:07 AM
tuneman's Avatar
Hi, no it never ran dry. I kept checking it and adding to it. I've done this before but never on anything this new. The times I have changed brakes on my trucks it was a straight forward pad, rotor, emerg. brake replacement. I just wasn't sure if being a newer vehicle if there were different steps i had to take or if something else could be wrong. For all i know there may still be air in the lines. Thanks, tuneman
Old 12-01-2008 | 01:43 PM
tomb1269's Avatar
Have you tried using an power bleeder or hand pump brake bleeder. Remember, most of our vans have panick assist brake systems which may play hell with us when trying to bleed the old way.
bamasmknmom
08-21-2012 03:46 AM
jhcantwell
11-11-2010 05:41 PM
jim333
04-07-2008 08:54 PM
ck
03-06-2008 05:12 PM
ck
03-06-2008 12:47 PM
