Can't read OBD codes
Old 08-16-2011 | 10:01 AM
sllimbri's Avatar
Default Can't read OBD codes
'05 Freestar--check engine light is on. I had two different shops connect their OBD reader but they can't read anything. It won't power up. One said the OBD fuse was blown. I checked all fuses designated as having anything to do with the PCM or OBD and all are fine.
Why is my OBD port dead?
Old 08-16-2011 | 11:30 AM
Thumbs up
Welcome to the site..
Check the Cig lighter fuse..
Old 02-13-2021 | 02:13 AM
Bond007ria8's Avatar
Any fixes?
Old 02-13-2021 | 12:09 PM
Like just about all things electrical, two things need to be available . Power and ground.
If,,,,,,,,,,,,,,,,,,,,,,,,you checked the correct fuses,,,,,,,,,,,,,,,,,and there was power to pin #16 of the DLC (Data Link Connector) , the other half of the diagnosis is to confirm the ground connections are good. Pins #4 & 5.
Old 02-15-2021 | 12:49 AM
so finally found out that fuse #11 on the inside fuse box was the culprit to my issues
issues:
1 rear liftgate ajar
2 interior lights on
3 no connection to OBD
apparently this #11 controls all of this, so liftgate was open so the lights were on, and the OBD is an extra for the fuse, i double checked it to be sure and its only a 5amp fuse! dammit ford!
Pappys2002
02-18-2022 10:30 PM
bjf128-
09-30-2012 12:59 PM
AWildrick
03-07-2012 01:28 PM
grun
06-10-2009 02:41 PM
fl_hayseed
04-20-2009 06:30 PM
Quick Reply: Can't read OBD codes
