cruise control switches
Old 01-23-2012 | 06:37 PM
impala's Avatar
Default cruise control switches
hi guys i have a 2006 ford freestar and i need to replace my cruise control switches on the steering wheel cover how do i remove the cover and how do i get the swiches out any help greatly appreciated thank you
Old 01-23-2012 | 09:21 PM
Whats the reason for replacing the switches?
The steering wheel needs to be pulled to remove the air bag and gain access to the switches.
First the SRS system needs to be inactive/powered down. Then, there's an access cover on the underside/back of the steering wheel. Behind the cover is the wheel attaching bolt and connectors. Once the wheel is off, there are 3 rear wheel cover screws. When the cover is off, a few spring clips to remove the air bag..
Old 01-24-2012 | 01:46 PM
impala's Avatar
the reason for replacing the cruise control switch was the on-off button was working but you had press real hard on it and then eventually it stopped working completely
impala
09-22-2012 02:23 PM
Fordman1949
05-20-2011 04:52 PM
AP
07-28-2007 04:01 PM
dkimbro
07-29-2005 01:13 PM
dkimbro
06-29-2005 03:15 PM
Quick Reply: cruise control switches
