Electronic Compass/Temperature display
Old 07-04-2007 | 10:08 PM
smwinegard's Avatar
Default Electronic Compass/Temperature display
We just recently bought a 2006 Freestar that the temperature display is flashing '-40F' at start up and eventually creeps up to around '-31F'. Is there a way to calibrate this like there is a way to calibrate the compass?? Any info would be greatly appreciated. Thanks
Old 12-31-2007 | 05:29 PM
marina06's Avatar
Default RE: Electronic Compass/Temperature display
I also have a problem with accuracy on my 05 Freestar. Did you get any help with your problem? Thanks
Old 01-22-2008 | 03:57 PM
JoceB's Avatar
Ditto here.... same problems... any help is appreciated!
Old 01-22-2008 | 04:50 PM
btexpress's Avatar
You should probably get the vehicle checked for codes, there is a Smart Juntion Box that includes the compass and temp displays, there may be a code that will lead to the problem. A few years before I would say the ambient air temp sensor is bad, but on a '05 or newer there is so much electronics involved it is a bit more complicated than just saying the sensor is bad.
jmesich
03-11-2010 02:16 PM
cceretti
12-13-2009 04:42 PM
ziggywoman
09-21-2008 02:47 PM
offroad1
04-07-2008 10:46 PM
zndad
03-10-2006 03:04 AM
